Resets the log target format to its default values.
console | Specifies the console display format. |
memory-buffer | Specifies the switch memory buffer format. |
nvram | Specifies the switch NVRAM format. |
session | Specifies the current session (including console display) format. |
syslog | Specifies a syslog target format. |
all | Specifies all remote syslog servers. |
ipaddress | Specifies the syslog IP address. |
ipPort | Specifies the UDP port number for the syslog target. |
tls_port | Specifies remote Syslog server Transport Layer Security (TLS) for connection type. |
tls_port | TLS port number. |
vr_name |
Specifies the virtual router that can reach the server IP address. Note: User-created VRs are supported only on the platforms
listed for this feature in the
Switch Engine v33.1.1 Licensing Guide
document.
local0 ... local7 | Specifies the local syslog facility. |
format | Specifies that the format for the target will be reset to the default value. |
When a target format is unconfigured, it is reset to the default values.
Use this command to reset the target format to the default format.
The following command sets the log format for the target session (the current session) to the default:
unconfigure log target session format
The udp-port parameter was added in ExtremeXOS 21.1.
Transport Layer Security (TLS) option added in ExtremeXOS 22.1.
